It is currently Mon May 25, 2026 12:39 pm
 Post subject: Suspension question
PostPosted: Wed Dec 02, 2009 12:44 am
Well I lowered my luv with 3" blocks in the back and just evenly cranked down the torsion bars in front. Took the rear springs out except for 2 and the overload. Well my truck sits lower on the driver rear and higher on the passenger front. I let the torsion down a few more turns on the passenger side and that didnt seem to matter much. Any ideas?
 Post subject: Re: Suspension question
PostPosted: Wed Dec 02, 2009 7:27 pm
Really chunkie girlfriend riding shotgun should fix it.
PostPosted: Fri Dec 04, 2009 2:11 am
are you siting on the rubbers
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Dec 04, 2009 9:14 am
dont know if you did this . but you normally have to drive it a bit to let it settle.
PostPosted: Sat Dec 05, 2009 9:45 am
Huh, guess where the fuel tank is at. Also the springs and torsion bar get used and wore more on the driver side.
Try putting Or exchanging a spring on the driver rear. Try pulling a short one and put in one that is longer this will help the spring hold more weight.
PostPosted: Sun Dec 06, 2009 9:23 pm
Well I figured it out...
Somehow the passenger side torsion was about a inch higher than the drivers....
Leveled them out and its all good now :)
What rubbers? :D
