It is currently Mon May 25, 2026 6:24 pm
 Post subject: Bagging a LUV
PostPosted: Wed Oct 28, 2009 6:00 pm
What all has to be done aside from the normal stuff... (knotching and what not)
I pretty much just want to know what the heck do you do with the front end.
 Post subject: Re: Bagging a LUV
PostPosted: Wed Oct 28, 2009 6:58 pm
gotta z the frame 1.5" to lay out
PostPosted: Wed Oct 28, 2009 10:28 pm
Have any pics? No idea what that means.
PostPosted: Thu Oct 29, 2009 8:49 pm
the control arms hold up the frame 1.5" off the ground, gotta cut the frame and "z" it to lay out. I don't have any good pics from my build up I don't think, but you can go check it out and see
http://forums.luvtruck.com/viewtopic.php?f=33&t=12675
PostPosted: Fri Oct 30, 2009 8:26 pm
check out mike (dallas hotrod parts) new control arms. that will help a lot. Z'ing the frame means you cut it, raise it up, then kinda ... .rebuild it after its lifted. if that makes sense. i know how to do it but cant explain it too well.
not a luv but i googled it and it kinda gives the idea.
and the back just notch the frame and do a 2 link, 4 link, whatever you choose. you can do bags on the bars, on the axle, its kinda personal preference. there is no technical wrong way to do it. i mean there is wrong way to do what you choose ... but there are pro's and con's to everything. there is no "perfect" set up
PostPosted: Fri Oct 30, 2009 9:16 pm
Thanks for the info. The back is fairly simple from what I gather but I hear the front setup on the LUV is pretty hard to bag compared to a yota or something.
But if I get the control arms from DHR what else would I need as far as bagging the front except the bags and brackets?
PostPosted: Sat Oct 31, 2009 1:38 pm
kinda depends. im going with a full s10 brake set up so i can swap to 5 lug. im getting the s10 balljoints in my arms when i order them. but you can use stock s10 spindles which are a dime a dozen. calipers, rotors, pads, etc. im doing this more/less because all of it needs to be replaced on my truck regardless. that and i get cost on parts at the parts store my friend works at.
overall if you do the dallas hotrod arms from the start, this truck is fairly simple to bag. i dont mean lay out. i mean bagged and functional
PostPosted: Sat Oct 31, 2009 6:34 pm
What about if you use s-10 drop spindles?
PostPosted: Sat Oct 31, 2009 7:07 pm
Stock spindles will for sure lay out on 18s. Drop spindles will work better with say 20s but its possible to lay out flat on 20s and stock spindles. For me .. Whatever I find cheaper is what I'm gonna use to be honest. And if you are gonna do a v8 I'd suggest v6 s10 spindles. I've been told they are cast different. I can't confirm that, its just what I've been told.
PostPosted: Sun Nov 01, 2009 11:13 am
Nah no V8 here the wonderful state of california doesnt like you to have anything cool.
PostPosted: Sun Nov 01, 2009 12:55 pm
then just go find an s10 in the junkyard and yank off the spindles.
PostPosted: Sun Nov 01, 2009 5:54 pm
What about getting some better gearing? I am already tired of winding out at 70mph.
PostPosted: Sun Nov 01, 2009 6:07 pm
literally the only thing i know mechanically about this truck is it is a 1.8L carb. id suggest posting that in the drivetrain upgrades section.
PostPosted: Tue Nov 03, 2009 1:47 am
Well, if you're up to it, the smog refs look kindly on putting a newer engine in an older vehicle... like say a complete transfer from a '90's vehicle (air cleaner to exhaust tip) ought to be good. If you're going through the front end right now, prolly should beef it up if you're even considering putting a newer V-8 in it.
BUT... talk to the local smog ref first.
PostPosted: Tue Nov 03, 2009 10:57 am
Ya I dont want to do a swap. Cali smog laws suck.
PostPosted: Tue Nov 03, 2009 8:07 pm
what year is your luv again? i live in cali and would do a v8 swap in a heart beat if i could get the one I want for my other luv. it can be done. and using s10 knuckles still is a little iffy for me though im considering it snice everyone here is doing it.
Hey if it works it works. buuuttttt...... :?:
1975 luv daily driver.
Project-soon to be revived
PostPosted: Tue Nov 03, 2009 8:46 pm
its a 76 still needs to be smogged lol. Its going to just be a crusing truck hence the bags. But I would like to get better gas mileage and not be so hard on the motor cause its also my daily driver.
PostPosted: Tue Nov 03, 2009 9:53 pm
TRUE that on the gas mileage. thats why im going with the ecotec motor and because its different from what every one on here is doing. so have you figured out what bag setup your going with?
PostPosted: Tue Nov 03, 2009 10:28 pm
Well I am getting all the stuff off my buddies 84 chevy it has airlift dominator bags in the back and slambags in front with 1/2" lines 7G tank and a offbrand compressor with parker valves.
PostPosted: Thu Nov 05, 2009 9:07 pm
when was the last time your luv was taged i got ((my 76 luv )) out of state and had to take it to the chp and becuase it was built in 75 that is what was stamped in the vin so now i drive a 75 luv :ewink
dangerous-toys4life
75 k-5 2x
94 king cab
