It is currently Tue May 26, 2026 1:38 am
 Post subject: VIN numbers?
PostPosted: Tue Oct 13, 2009 1:23 pm
Where are the VIN on a Luv truck?
 Post subject: Re: VIN numbers?
PostPosted: Tue Oct 13, 2009 3:33 pm
My truck has a metal plate inside the drivers door by the latch with the vin on it.
PostPosted: Tue Oct 13, 2009 4:47 pm
thats where im is too but its starting to get hard to see . i have been told that there is a vin on the frame but i have looked and i have not found it yet
PostPosted: Wed Oct 14, 2009 9:24 am
pull the cowl vent.
its the tray where the wipers pass in the front.
under it on the drivers side is one of the body vins.
A.j.
PostPosted: Wed Oct 14, 2009 10:58 am
If it is on the frame it will be on the trans X member facing forward on the driver side between the trans and the torsion bar.
PostPosted: Fri Oct 16, 2009 2:02 pm
use some steel woul on the vin plate and it will show up better
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Oct 22, 2009 10:49 am
No stock trans x member. I will see if I can look under the cowl. They need to see one to do a State Inspection on it.
PostPosted: Fri Oct 23, 2009 10:21 am
with the one on the door jam tape it off spray a lil black paint then wipe it off and the paint will stay in the groves were the # are and you can see it better if you just take it to the chp they will look it up for you
dangerous-toys4life
75 k-5 2x
94 king cab
