It is currently Mon May 25, 2026 12:39 pm
PostPosted: Fri Jul 31, 2009 7:44 pm
I scored a set of doors that are completely smashed and rusted off of a 78 Luv 4x4, they are one piece glass with no vent. My 1975 model has vent's, can I swap? They look different in the way they mount, as well as the very corner of the glass might take a different piec,e that i might be missing off the 78. Thanks........
PostPosted: Fri Jul 31, 2009 7:58 pm
my 76 has vent less but i am new too this most of my mods were done long before i got it
PostPosted: Fri Jul 31, 2009 11:12 pm
i was told you can swap doors back and forth
PostPosted: Sat Aug 01, 2009 6:18 pm
True. You can also swap out the window components with a bit of work such as additional fastener holes to put vent windows in a later year LUV.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Aug 04, 2009 1:11 am
I can't swap the doors. Not unless I want rusty primered, caved in doors. I'll try this weekend to swap one and see how it goes.Image
PostPosted: Wed Aug 12, 2009 8:22 pm
Have you swapped out those doors yet. I sent a PM for some info too.
Rick
Loranger, La
PostPosted: Wed Oct 07, 2009 7:23 pm
ive been told you can just swap out the glass. i have a 77, my donor truck is an 80 and someone said the glass will just swap. if not .. ill just swap doors
PostPosted: Thu Oct 08, 2009 12:20 am
aren't the the mechanical part of the window crank a different size w/ diff. mounting holes?
76 mikado project,mean green
PostPosted: Sat Oct 10, 2009 11:07 pm
i am going to look into this so if any new info is out theere let me know if not i will look into it in the coming weeks :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
