It is currently Mon May 25, 2026 9:51 pm
 Post subject: master cylinder
PostPosted: Wed Jul 01, 2009 8:53 am
i converted to disc brakes but i forgot which master cylinder i could use what luv year is bolt on with disc and a booster
thanks again Ctmandu
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
 Post subject: Re: master cylinder
PostPosted: Wed Jul 01, 2009 9:04 am
Well I think since 76 was the year they went to disc brakes, you could get a 76 or later master and use it. Even 73 or later is an improvement, you know a 72 only has one cylinder for both front and rear brakes whereas in 73 I believe they switched to a system separating front and rear. I think I have even heard stories of people on here using other Chevy master cylinders without a booster.
