It is currently Mon May 25, 2026 12:39 pm
 Post subject: Stock gas tank - V* SWAP
PostPosted: Thu May 28, 2009 3:06 pm
I know this is probably a crazy question. I have done a V8 swap and I am running the stock gas tank and I am not sure which line to use coming from the tank. Does anyone have a pictures of a stock tank set up with V8 swap so I can see how to connect the gas line. I am running a mechanical fuel pump with a Eldebrock carburetor. Also what would be the recommended size of fuel line.
Please HeLp
PostPosted: Sun May 31, 2009 12:07 am
The one that comes straight out of the tank, and has a little circle raised up around it.
PostPosted: Mon Jun 01, 2009 7:01 am
Thank You
