It is currently Mon May 25, 2026 10:56 am
 Post subject: quick question
PostPosted: Thu May 21, 2009 12:05 pm
When installing my stereo what color is the wire on the ignition that i use to conect to my stereo?
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
 Post subject: Re: quick question
PostPosted: Thu May 21, 2009 6:04 pm
well that depends on which wire you are trying to hook up, the 12 v switched or the 12v constant, if you have a test light it wopuld help immencely
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Thu May 21, 2009 8:43 pm
It is the 12v switched and my test light has gone MIA!
PostPosted: Fri May 22, 2009 5:53 am
well without a test light its kinda difficult to find which wire on the ignition comes on when the key is turned to acc. there are other ways tho, if your fuse box is labeled pick one of the fuses that you know only comes on with the key like the heater or turn signals and run a wire to that, also that way the wire is fused and "most likely" wont burn anything up
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
