It is currently Mon May 25, 2026 8:05 pm
PostPosted: Tue Feb 03, 2009 2:27 am
hello everyone I figured I would let everyone know of one option that I came across and works great too
now for everyone who reads some of my posts will see that I use alot of import parts(honda/acura) well thats partially because I have owned many integra's and civic's and because the parts seem to work great plus the LUV just happens to have the same size nuts and bolts as the acura's and honda's....
I will also show a few of the things I have done with my import parts...
first will be the door trigger...My trigger came out of a 94-01 integra or 92-95 civic I am not sure of which but I believe they are both the same....
if you look carefully at the picture below you can see a small dot on the door itself that is where the door trigger contacts the door..may be a useless picture but some people may want to see it
I have also used black integra retractable seatbelts instead of the LUVs original two piece POS ones there are a few other things but its late and I am tired and can not remember
PostPosted: Tue Feb 03, 2009 10:23 am
A+
PostPosted: Tue Feb 03, 2009 9:09 pm
im more of the type that removes those annoying noise makers but it looks like a clean install, good job
PostPosted: Sun Feb 08, 2009 1:46 am
thank you very much I wont be putting in buzzer this is more for the dome light and security issues
PostPosted: Mon Feb 09, 2009 5:34 pm
im not one for door buzzers.
but if it was just turning on the cab lite, thats a good thing.
mine does not work :lol:
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Feb 09, 2009 5:52 pm
I like it. Nice job.
Did you use a honda dome light too? I really like the feature that my '87 Prelude dome light has. When you close the door, the dome light doesn't just shut off, it gradually dims until it goes dark. I'm guessing there's a capacitor in the system somewhere. Not sure if it's in the dome light assembly its self or elsewhere.
Eric Q.
My build thread.
PostPosted: Sun Feb 22, 2009 4:48 pm
Eric Q.
as of right now its just the factory luv light but you know what I never thought of using a honda/acura dome light too that is a dang good Idea I I think I will look into it and see if I can mock one up but I am not sure about the civic ones working because they are about three times the size of the luv ones.
thank you everyone who has put in thier two cents its apreciated and yeah deffinitely no door ajar buzzer for the LUV but I think I may do a headlight warning buzzer not sure because I am going HID soon :twisted:
