It is currently Mon May 25, 2026 8:06 pm
PostPosted: Fri Jan 30, 2009 4:10 pm
This is an idea I had for adapting a Trailing Arm rear style suspension to the LUV. The thought I had was to use as much of the stock mounting (axle pads, current bolt holes in frame, etc) as possible. The trailing arms would be made from 2 X 3 square tubing (wall thickness need some advise on). They would connect to brackets on the crossbrace at the back of the bed on the frame. The bushing would be boxed into the crossmember side of the Trailing Arm. More detail to come.
This is what happens during a slow day at work with Google!!! :roll: (Sorry about the poor drawing)
Any idea , thought, critizing welcome please!!
File comment: This is the general idea
PostPosted: Sat Jan 31, 2009 1:57 pm
That kind of setup wouldn't be very beneficial on a luv because of the boxed frame they have. The trailing arm setup itself doesnt give any flex side to side, so on the full size chevy's, the frame is designed to twist when you pull into a driveway at an angle etc. If its strictly for a drag truck with limited suspension travel this would work just fine. But on the street it would really twist up the backhalf of the frame.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Jan 31, 2009 2:10 pm
Thanks for the info
PostPosted: Sun Feb 01, 2009 12:55 pm
It woud work better with Heim joints up front for a little twist but would still be limited.
PostPosted: Sun Feb 01, 2009 3:10 pm
http://www.midwestcontrol.com/catdisplay_short.php?pg=555
What about a High Misaligment Hiem Joint?
PostPosted: Sun Feb 01, 2009 6:23 pm
Better yet but still need a panhard bar or watts link to keep rear end in line.
PostPosted: Sun Feb 01, 2009 6:28 pm
How about just using ladder bars whith the leaf springs (no panhard bar)
PostPosted: Mon Feb 02, 2009 4:08 am
Trying to eliminte the leaf springs. I have heard that lader bars are not real good for street use,
