It is currently Wed Jul 01, 2026 10:43 am
PostPosted: Mon Jun 02, 2003 8:50 am
I raised the front of my Luv a good inch (was slammed). So now I'd like to get the thing
to ride good, shocks are gone. I need some good/cheap shocks, for front end - to help
handling. Any shocks you guys use or recommend for a smooth ride?
Also now I feel the rear suspension, what can I do to get a smoother ride in the back?
Can I remove one of the long leafs on each side, will that make it smoother? Anyone
done this?
Thanks
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
 Post subject: shocks
PostPosted: Mon Jun 02, 2003 9:01 am
Japanese Redneck
you get what you pay for. If you buy the $15 Gabriel gas shocks you get an ok ride but if you get some nice Bilsteins (about $60-$70) you will definitely tell the difference. some other shocks that I have used and liked in the past:
Doetsch Tech
Rancho
Competition Engineering
I currently run Lakewood 90/10 or CE adjustables in the front.
PostPosted: Mon Jun 02, 2003 1:18 pm
try taking the last 2leaf spring on the back on each side that helped so much on my truck i felt like i was riding on a car not a truck no more :)
 Post subject: *
PostPosted: Mon Jun 02, 2003 1:55 pm
Last 2 leafs meaning?
The "long" ones underneath the top one or the 2 "short" ones
near the bottom?
Thanks, thats what I was lookin for!
PostPosted: Mon Jun 02, 2003 2:17 pm
the last two short ones the realy thick bottom one and the next one that starts to bend up
PostPosted: Mon Jun 02, 2003 2:19 pm
u might need to add a couple of washers after u take the 2 leafs springs out or if u can find some shorter U looking things i forgot what its called
