It is currently Mon May 25, 2026 9:19 pm
PostPosted: Sun Jun 15, 2008 2:12 pm
i would like to see some pictures of the mounts that ya'll have fabricated up for the swap, i have seen a couple of them already and would like to see more. i really don't want to spend 130.00 on the hookers so give me some ideas guy's.
PostPosted: Tue Jun 17, 2008 7:42 am
well.......i take it we have no fabricators on this site???? come on guys give me a hand here.
PostPosted: Tue Jun 17, 2008 8:23 am
PostPosted: Tue Jun 17, 2008 8:28 am
thanks Terry...the tops pics are the hookers correct.
PostPosted: Tue Jun 17, 2008 8:35 am
The frame mounts are home built and the block mounts are Moroso solid mounts.
PostPosted: Tue Jun 17, 2008 10:07 am
I'll try to get a picture this weekend
PostPosted: Tue Jun 17, 2008 10:48 am
Do the mounts go before or after the front suspension?
PostPosted: Tue Jun 17, 2008 3:31 pm
I didn't do the work, but here are mine...
Hotrod80 identified these as modified '68-'72(?) chevy truck mounts...
PostPosted: Tue Jun 17, 2008 4:03 pm
i would have too agree with hotrod on that.
PostPosted: Tue Jun 17, 2008 4:50 pm
Here are mine . All part from Lowe's metal shelf , 1st gen Camaro sbc captured mounts . Kinda a T-type design with tubing or pipe for the mount bolt to go thru . Also tubing going from mout bar to frame in the front . Should of added tube to the rear of the mount also . Did that make it clear as mud .
PostPosted: Wed Jun 18, 2008 3:56 am
thanks guy's, i knew i could count ya'll. :D
PostPosted: Thu Jun 19, 2008 7:32 pm
Not on my luv but the same idea.
PostPosted: Fri Jun 20, 2008 8:54 am
Thanks lotta luv i like those ......look easy and simple to do.
PostPosted: Sun Aug 24, 2008 5:04 pm
I dont have any pics of my motor mount but the problem that i was running into was busting trans housing with a turbo 350 with stand swap mounts and a mid-engine plate, but i am now running a front engine plate that i made and trans mount only and no longer busting housing. I will take some pics of it if you like because i made mine where it doesnt bolt up between the water pump so its easier to pull the engine in and out.
William "Crazy Cooter" Nelson
PostPosted: Sun Aug 24, 2008 6:49 pm
Hey nukeday, I see that you have the front part of the truck off (that part that holds the headlights and grill). Is that spot welded on? I didn't see any screws and was apprehensive about drilling out spot welds.
Eric Q.
My build thread.
PostPosted: Mon Aug 25, 2008 4:55 pm
Eric Q -> PM Sent.
If it turns out later it's relevant to this thread we can come back and put stuff in.
