 Post subject: 4wd to 2wd conversion
PostPosted: Thu Apr 24, 2008 11:30 pm
I have a 79' 4wd that I swapped a 350 into. I took out all of teh 4wd parts, front diff., clutch stuff, etc...but I still have the 4wd front spindles. I pulled a pair of 79' 2wd spindles and want to put them on but will I run into problems? They look like they'll fit right in. I also need to fabricate a crossmember since there is one on the 2wd and I guess the front diff. on the 4wd acted as one. Has anybody done this?
PostPosted: Fri Apr 25, 2008 4:56 am
Australian LUV Guru
The 2wd spindles will bolt straight in.
I would not have used the 4x4 frame for a 2wd v8 conversion, the 4x4 frames use a different lower control arm and shock arangement than the 2wd. With the 4x4 frame if you want to pull the torsion bars and fit coil overs you will need to do some fabrication work, also i,ve read that the 4x4 front will not wind down as low as a 2wd.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Apr 25, 2008 5:52 am
I appreciate the reply and I feel better about attacking the spindles now. The 4wd sort of fell into my hands so I made it work. The torsion bars don't seem to be a problem yet. I'm running block huggers with plenty of room. The torsion bars seem thicker on the 4wd than the 2wd and I kind of like that. I'll try to post pics if I can. Thanks again.
