It is currently Tue May 26, 2026 12:14 am
 Post subject: Repair Cost
PostPosted: Wed Jun 25, 2008 12:34 am
I started sanding down the really crappy primer job on my 79 LUV today to prepare it for priming/painting, and discovered something rather frustrating. On the panels with the vents behind the doors, I found two holes completely rusted through covered with a tacky bondo job. Once all the bondo was removed, I looked through the hole (about a quarter-size in diameter) and found that at least directly behind it, the metal of the cab has rusted. Before I go hacking off panels and making myself crazy, I figured I'd ask the people who may have been in this situation before. My first question is, how much would it cost to have my truck taken to a body shop, have them remove the panels, cut out the infected area, weld in replacement metal, and replace the vent panels? I would do it myself, but I am not a confident welder by any means, though I have a few friends who do their own body work. I am hesitant to ask them though, because it seems like it would be a difficult task, and I'd hate to destroy the little truck. Or is it possible I have bitten off more than I can chew, and should just sell/scrap it and get out while I still have some money left?
 Post subject: Re: Repair Cost
PostPosted: Wed Jun 25, 2008 1:38 am
If you can reach it enough to get the scale off, this thread might be helpful...
viewtopic.php?f=7&t=7163&start=0&st=0&sk=t&sd=a&hilit=ospho
PostPosted: Thu Jun 26, 2008 7:56 pm
You could take your truck to a couple of body shops and get a quote.
Another option would to find another cab and swap it over.
PostPosted: Thu Jun 26, 2008 8:07 pm
Most body shops would just want to bondo over the holes. Good metal repair is almost a art. It is not beyond most people, but you need access to some kind of welding equipment. Electric or gas. Some community Colleges have a body repair program and they might be a good place to check and see if this would be a job they would want to work on.
Good luck with getting your Luv going like you want.... Ask and we will try to help you out....
Richard
PostPosted: Thu Jun 26, 2008 8:29 pm
Can you post up a few pics of it?
Then the folks around here can see the extent of the damage and be better able to assist you.
PostPosted: Mon Jun 30, 2008 11:53 am
Another quick thought here...I came across a couple of Luv's at a wrecking yard in Eugene. The earlier one ('76?) is really nice and rust free, even the rockers looked clean.
I can give you contact info if you think you want to swap the cab...
