It is currently Wed Jul 02, 2025 9:05 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jun 15, 2011 1:01 pm
Lesson on Trooper upper control arms.
When installed you will not need the bumpers that the stock control arms would set on when lifted.
After installing the control arms lift truck so the front is in the air and at full droop then loosen the bolts on the control arm pivot shaft and let the bushings turn then tighten the bolts you are now ready to use them and they will work like they were made for your truck .
Good luck with your conversion i sure enjoy mine.
PostPosted: Wed Jun 15, 2011 1:14 pm
This is a great idea, now that I just finished rebuilding my whole front end and got an alignment. DOHH!! :smt099
PostPosted: Wed Jun 15, 2011 4:14 pm
Been there,done that, got the T-shirt
PostPosted: Tue Aug 23, 2011 10:49 am
so does any one have some trooper arms they would like to sell me?
PostPosted: Sat Feb 09, 2013 12:28 am
It's revive a dead thread day!
.....So upper arms from an 86 Trooper II will work? i have found a couple of these in local yards, but nothing earlier.
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Tue Apr 22, 2014 7:18 pm
anyone know if the 1986-84 pup upper control arms are the same as the troopers?? i have a good deal on them and need to know before i buy.
PostPosted: Tue Apr 22, 2014 7:53 pm
i believe they share the same chassis between 84-86 and probably later but it was changed in later models
PostPosted: Tue Apr 22, 2014 8:00 pm
ah! beautiful. thank you.
PostPosted: Tue Apr 22, 2014 11:46 pm
just make sure you take a good look at them before you buy them. i know i have read its all the same between puos and troopers but i havent tried the swap myself
