It is currently Tue May 26, 2026 1:38 am
 Post subject: tilt column
PostPosted: Sat Jul 22, 2006 4:02 pm
anyone do a tilt coulumn here, i am getting ready to do one and wanted and ideas that mey help with the instal. i pulled this one out of a chevy chevette so its the general GM column, thanks
PostPosted: Sat Jul 22, 2006 7:39 pm
My 80 4x4 has one, from a Buick or Olds I think. I didn't put it in though, but I could take some pics. They basically sleeved the cut stub of the original shaft to the tilt column shaft I think.
PostPosted: Sun Jul 23, 2006 12:42 am
Well I pulled the chevette column today took about 10 min. was easer then I thought it would be. I have taken out pinkskys column to do a trial fit and every thing look like it will be a go with a little mod here and there. So tomorrow will be an R and D day.
PostPosted: Sun Jul 23, 2006 1:01 am
will you get some info and pics of what you do and did 4 us
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Jul 23, 2006 1:25 am
once i get it all figured out and am ready to install it ill take pics from start to finish for everyone . and also what parts are needed to do it all from column to box
right now everything is just test fit and see how to do it right the first time. then everything will be transferred to my truck and then hers put back together
PostPosted: Sun Jul 23, 2006 3:07 am
cool thanks
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Jul 26, 2006 7:41 pm
hay how about some pics, thanks
PostPosted: Thu Jul 27, 2006 12:51 am
I'll get some tomorrow for ya. I'd like to find out what this one came from anyhow, it BADLY needs a Grant wheel or something. If you hold the wheel and close your eyes you can almost hear Grandma yelling at the grandkids in the back seat.
PostPosted: Tue Aug 01, 2006 9:14 am
any luck yet on the pics
PostPosted: Wed Aug 23, 2006 10:18 pm
Ok so I found a better column from a 64 Chrysler 300 and wont use the chevette one. The Chrysler is the style I wanted (simple, clean, no key, just tilt and turn signal) and easier to do. Pulled the luv column out cut it to the length I wanted had the end lathed down to fit the 9/16 Chrysler end. Will use the stock column mount that goes to the floor (cut to fit). Will get an adapter that will step down from the column to the floor mount for the luv. and it will go together like this
PostPosted: Tue Jan 22, 2008 9:36 pm
Hey cat...was the chevette column a bolt up or does it require some machining? Unfortunately my stepson is far too long legged for the stock column...his knees are in the steering wheel when he clutches or brakes. Until we can get this solved we are at a standstill on the project. Just let Terry know that he wants to change the look to a 4x2...his idea, mine was turning it old school with big-n-littles.
PostPosted: Tue Jan 22, 2008 11:27 pm
it would of need some mods, no bolt in tilts i know of out there... if you go here ---> http://www.chevyluv.zoomshare.com/1.sht ... t%20column this will show you how to do one ... or its trial and fit like i did mine but it was easier then i thought it would be... keep me posted on the truck and maybe some pics from time to time... ill let terry know but he is still in korea until june
