It is currently Tue May 26, 2026 5:07 am
 Post subject: Rust Inhibitor
PostPosted: Mon Jan 21, 2008 5:08 pm
I have some rust holes in the body I have cut and sanded most of it away , I just have a question for anyone thats used Rust Bullet as i cant see mention of it on the rustbullet site , can car body filler be applied over it, It says it will take paint but nothing about filler , I just wanted to know from someone who used it before .
thanks
PostPosted: Tue Jan 22, 2008 8:39 pm
after you put on the rust bullet stuff you have to neutralize it. most of the time you use steal wool and some water. after you clean all the stuff off you need to put a seal coat over it like primer. do a few coats. let them dry and after its all dry you need to scuff it you with sand paper like a 120 grit then do your filler work.
PostPosted: Tue Jan 22, 2008 9:52 pm
Thanks for those tips
PostPosted: Sun Jan 27, 2008 9:02 am
If I am not mistaken POR15 you can put filler right over the dried product
