It is currently Tue Jun 30, 2026 1:26 am
 Post subject: mounting radiator????
PostPosted: Sat Dec 29, 2007 10:32 pm
i was looking at the v8 swap article and im not sure on ho to mount my howe radiator. do i cut the core support all the way to the frame? and if i do how do i mount it, also how much of a gap should i have between the radiator and the water pump? pictures will help a lot
THANKS
PostPosted: Sun Dec 30, 2007 6:15 am
Here's mine with the Howe .
PostPosted: Sun Dec 30, 2007 10:57 am
how much of the lower crossmember did you cut out?
PostPosted: Sun Dec 30, 2007 11:38 am
On the frame ?
PostPosted: Sun Dec 30, 2007 1:24 pm
so the radiator is sitting on the frame of the truck? or the lower crossmember on the radiator support panel? how much of a gap do you have from the water pump? is chassie flex an issue? and thanks for all the help
PostPosted: Sun Dec 30, 2007 3:57 pm
The frame on my truck is not cut . Chassis flex is not a big issue with these trucks as they have 6 cross members . The core support is cut and bent so it cradles the bottom of the radiator it is isolated from the core support by fuel hose . There are also tabs mounted from the radiator to the strut rod crossmember . The top , where the hood hinges mount , was cut back and the top of the radiator was mounted with angle iron . There is approx. 1 1/2 " between the fan and radiator . I had to move it forward 3 times to get the proper distance . But it is easier to cut more metal out than it is to add metal back . I cut the factory rad mounts back to the C channel on both side . If you put the new rad up to the old hole it will be easier to see what has to happen . Also the brace that goes in front of the rad in one of my pictures in now gone also . It is the one behind the bumper . Hope this helps . I might get some better pics tonight or tommorow .
PostPosted: Sun Dec 30, 2007 4:02 pm
O.K . I see the pictures without the fan are of my first setup with the electric fan . They give you an ideal how I mounted it . The last picture is my current setup with a flex fan . Again i'll try and get some current pictures .
PostPosted: Sun Dec 30, 2007 6:44 pm
thanks for the help i think i know what to do now. and in the fourth picture is that the tranny cooler?
PostPosted: Mon Dec 31, 2007 5:37 am
Yes , and an electric fan as a pusher .
 Post subject: Re:
PostPosted: Tue Mar 04, 2008 4:24 pm
I love your truck :roll: :D :ebiggrin
PostPosted: Wed Apr 02, 2008 12:42 am
here is how mine is set up with the stock size radiator
PostPosted: Wed Apr 02, 2008 11:31 am
hey will the stock radiator work for a v8? like i just got mine re done and dont want it to be a waste :(
PostPosted: Wed Apr 02, 2008 5:14 pm
i believe mine has one more row than a stock one does but i still run cool
