It is currently Tue Jun 30, 2026 6:20 pm
 Post subject: Bushings Door and Body
PostPosted: Wed Apr 30, 2003 8:57 pm
I bought some Jeep poly body bushings and with a little modifacation they are going to work.
I also have door bushings figured out for the upper hinge. Will work on lower hinges next week.
I will post all part #s Tomorrow!
stripped and just a memory!
PostPosted: Thu May 01, 2003 4:57 am
RAT is THE MAN!!!!!!!!!!!!!!!!!!!!!!!!
p.s. thanks for the parts.....if I took anything you want let me know and I will get them back to you.
03Cobra
PostPosted: Thu May 01, 2003 12:25 pm
While on the subject of hinges, i've noticed that alot of trucks have broken spring assy's on the lower hinges. Is this a cronic problem that many face?
PostPosted: Sat May 03, 2003 7:37 am
Yea the hinges on my 80 were broken like that. Had to find me some new ones.
PostPosted: Sat May 03, 2003 9:47 am
Resident Sparktrician
As of yesterday, I now have F.U.L.D.S (Fucked Up Luv Door Syndrome) too. I opened the door at school and it hasn't closed correctly since! 8O I'll be looking forward to your info too RAT.
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sun May 04, 2003 8:05 pm
I have not gotten to the bottom hinge but with a little work # 38390 in the HELP! section will work on the top. They are Chrysler bushings and I didn't use the pin. They fit the hinge but use a 1/4" pin instead of the 8mm or 5/16" the Luv originally used. At the local Hardware store I found bushing that were 5/16" Outside and 1/4" inside this allows for the use of a 1/4" grade 8 bolt and a nylon lock nut for a pin. You will have to file or grind the hinge for a little clearance on the thrust side of the bushings but with a little time and effort you can have a tight door hinge again.
PostPosted: Fri May 16, 2003 12:18 am
On body bushings.I just picked up some hockey pucks,paid like $2.00 a piece.They're hard rubber and a little mod. will work good.Just go to your local Ice hockey rink
PostPosted: Sun May 18, 2003 8:13 am
OG Lifer
I guess that is better that an old tractor tire sidewall. That was gonna be my next attempt at making body bushings.
WATCH YOUR PIEHOLE!!!!!!
