It is currently Tue May 26, 2026 9:37 am
PostPosted: Thu Dec 13, 2007 8:55 am
Recently we went to change the plugs on my baby and had the hardest time trying to get one in well after trying for about 2 hours we finally decided to dig deeper and found that my head is warped (at least thats what i think) correct me if i am wrong i am new at this but its oval shaped and i know its not suppose to be like that what should i do i would like to put a new motor in but idk HELP ME!!!!
PostPosted: Thu Dec 13, 2007 12:16 pm
PITA Old Fart
Huh???
Pics please.
PostPosted: Thu Dec 13, 2007 12:46 pm
Super,are you trying to say that the hole where the spark plug goes appears to have warped to where it's oval shaped and the plug won't go back in?
PostPosted: Fri Dec 14, 2007 7:59 am
Your problem is more likely the plug hole is striped out as most people do not know that you should always use antisieze on the plugs in aluminium heads.
There are kits to repair the plug hole but i suggest that you take it to a shop to get it repaired as it can be done with out taking the head off by somebody that knows what they are doing.
PostPosted: Tue Dec 18, 2007 11:19 am
yeah... if you mean the spark plug hole is oval shaped, there's a problem...not sposed' to be like that.
PostPosted: Mon Dec 31, 2007 3:49 pm
Well i figured that it shouldn't be oval shaped so i am just gonna buy a rebuilt motor to save the trouble
