It is currently Mon May 11, 2026 2:02 pm
 Post subject: 4x4 cab on 2wd frame?
PostPosted: Sat Nov 24, 2007 3:37 pm
i was wanting to know if there is any thing that will have to be changed
Im luvin it
PostPosted: Mon Nov 26, 2007 8:54 am
i'm pretty sure that the 4x4 cab is the same as the 2x4 cab, the only difference between the two pick-ups is the suspention (not posative), but i even think that with a few little things you could make a 2x4 a 4x4
-Dustinicus
PostPosted: Mon Nov 26, 2007 2:57 pm
PITA Old Fart
The 4X4 cab has a different shifter hole setup - other than that - I think they are the same.
PostPosted: Mon Nov 26, 2007 4:24 pm
i knew i was forgetting something, thats nothing that a little sheet metal couldnt fix though
-Dustinicus
