It is currently Mon May 11, 2026 3:42 am
 Post subject: Upper ball joint
PostPosted: Sat Oct 20, 2007 10:31 pm
Upper ball joints whats the best way to remove them? I'm putting the S-10 spindles on.
PostPosted: Sun Oct 21, 2007 9:13 am
Try and locate a wrench or socket big enough to fit the nut. If you search for upper ball joint in the search you'll find a tread that has the size on it. If you can't get them off with a socket you will have to heat the crap out of them and air chisel them off. The nut that is, not the ball joint.
Craig
 Post subject: ball joint
PostPosted: Sun Oct 21, 2007 8:37 pm
Thank you for the help.
PostPosted: Mon Oct 22, 2007 2:18 am
Or in the case of the old joint, weld something to it that you can a hold of.
Bob.
