It is currently Fri Jun 26, 2026 5:29 am
 Post subject: body dropped problems
PostPosted: Thu May 31, 2007 11:16 am
I am in the process of doing a 4" body drop and 4-link. Has anyone had a problem with the front suspension not laying the frame down to the ground? When the cab is on the frame the back of the cab touches the ground but the front suspension will not allow the frame to lay down. My problem I think is with the upper balljoint. The joint seems to be past its limits of travel and not allowing the suspension to travel up more. I do have enough weight in the front with the SBC.
Thanks,
Craig :?:
PostPosted: Thu May 31, 2007 1:35 pm
do you have a drop spindle on it if not that might be what you need if you can put sum pics up so we can get a better look at it ok ttyl
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu May 31, 2007 2:04 pm
Do you know of a company that makes spindles for the luv? I will post some pic's tonight.
PostPosted: Thu May 31, 2007 6:11 pm
this sounds a little silly ,but did you check the bumpstops already?If it is the upper ball joint you could make new upper a-arms to fix the problem
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
 Post subject: pictures of ball joints
PostPosted: Thu May 31, 2007 7:28 pm
lets try to upload the pics
 Post subject: Pic's of ball joint
PostPosted: Thu May 31, 2007 7:38 pm
I cut the lower bumpstop bracket out and notched the cross member to allow the control arm to piviot ever higher than if you just took the bump stop out. The idea that I have in mind is to fab up a new upper control arm that allows the ball joint to be more in line. I do have a parts truck that I am stripping.
PostPosted: Thu May 31, 2007 8:12 pm
From what I can seein the last pic, the upper joint looks OK. Is the upper a frame hitting the shock pocket? Looks like it in the pic, but I can't see it straight on.
PostPosted: Thu May 31, 2007 8:25 pm
ok i have sum ideas 1 is jack up the truck and unbolt the upper a arm and then with the a arm in the air set the frame down and 2 is it looks like the bars that go from the frame the the lower a arm look like they are hitting the front of the frame ok let us know what you find out ttyl :lol:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu May 31, 2007 9:27 pm
I think mytmouz is right,you could cut some of the flat out of the arms and then use solid bar stock welded in the outer channel to stiffen it back up.(nothing a torch and welder can't fix)that's what we have done on stock armed race cars to clear the jacking screw
[color=#FF8000]
PostPosted: Thu May 31, 2007 10:10 pm
Uncover that Harley and take it for a ride to think about it :lol: :D
PostPosted: Thu May 31, 2007 10:51 pm
how'd you know i have a Road King ? :lol: :lol:
[color=#FF8000]
PostPosted: Thu May 31, 2007 11:37 pm
I am talking to ridgway, you can see his bike in the second picture.
PostPosted: Fri Jun 01, 2007 1:29 am
I saw that...was attemting to be funny :)
[color=#FF8000]
 Post subject: body drop problems
PostPosted: Fri Jun 01, 2007 5:44 am
Ok let me try unbolting the upper control arm tonight and see if it allows the lower control to travel up more. I will post some more pics tonight of the bump stop that I cut out.
RIGHT AFTER A RIDE!!!!! :D
PostPosted: Fri Jun 01, 2007 3:27 pm
pee_roys truck doing the same thing. i was thinking why not redrill the uper control arms so thay sit higher on the shock tower. just a thoght.
looking forwerd to more picks.
PostPosted: Fri Jun 01, 2007 3:57 pm
When I was tearing mine down I couldnt get the front to lay frame without the torssion bars or shocks either.
Mine would only go down about as far as where yours is at.
I kind of think that the ball joints bind up before the frame will get that low, I didnt see anything else that was stopping it. Maybe it was the lower control arm... Im not really sure.
I have some new ball joints that I can take a pic of to show how much they will bend if you want to look at them.
PostPosted: Fri Jun 01, 2007 5:57 pm
OK, when I took the upper control arm off the lower one went up completely to the frame. This is great news because that will allow the suspension to sit a low as possible. the upper control arm will rotate completely around to the inside of the frame. The upper ball joint is limiting the travel. I think I'm going to fab a new section of the upper arm at the ball joint location. I do have another complete truck that i'm stripping for parts. On that truck i'm going to cut out the ball joint section of the upper arm and weld it to my arm to allow the ball joint to stay more inline than the extreme angle it is at now. Does anyone know if drop spindles are available? I am having 1" spacer machined to get the spindle up off the lower control arm to get the truck even lower. If drop spindles are available that would be GREAT!!!
PostPosted: Fri Jun 01, 2007 11:16 pm
i am looking into that my friend owns his own shop (KUTS-R-US)1-559-784-5887 i will see what we can get for that :lol: also you can cut a pie out of the bottom of the upper a arm so the ball joint will be in a better angle and then weld it back together :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Jun 02, 2007 4:09 am
Ooops didn't see this post^^ Sorry :oops:
Just pie cut the upper control arm and re-weld it.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Jun 02, 2007 11:47 am
you might have to cut the front of the frame and move it up. i was looking at mine and the lower control arms and cross brace sits lower than the frame
