It is currently Mon May 25, 2026 10:34 pm
 Post subject: Tiling My Truck...
PostPosted: Sat May 19, 2007 6:52 pm
So I am Tiling my truck... No I am Serious, I have picked up some Stone look Self stick floor tiles at the Depot and have started making my Head liner, I will also be doing my dash in the same. I have only got couple layed so far as the weather has not been on my side. I will be doing the floor in Linoleum, Probably wood grain, easier to rinse the mud out. I will get some pics up soon.
'76 MUD project, 1 ton axles, lockers, 20" Lift, Big Smallblock, On board air, 54" Boggers, Hummer Double beadlocks, External Rollcage... in the works.
 Post subject: .
PostPosted: Sat May 19, 2007 7:06 pm
Tile?? Like with grout and mortar tile? Man I hope you have some realy smoth roads where you drive. :)
As far as the floor and tub goes, consider bed liner spray? looks good and can still hose it out if necessary.
FIAA: Color Guard
PostPosted: Sat May 19, 2007 7:14 pm
It's Vinal flooring tile, 1ft x 1ft squares, I am using industrial strength adhesive to hold it on, this is an off road only truck, plus flooring is different...
PostPosted: Sat May 19, 2007 9:55 pm
PITA Old Fart
Uhhh....OK... 8O 8O 8O 8O
PostPosted: Sun May 20, 2007 3:39 am
I've seen tile in custom semi trucks but never a luv. That should be cool.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun May 20, 2007 7:29 am
Cheap too, youd only need like three of em. lol. Not much roof in a luv.
If its an off roader just cut the roof out and bar it up. That way the guy with the spotlight and the guy with the gun get to have nice warm legs. :wink:
Cheers, Bob.
PostPosted: Thu May 24, 2007 11:34 am
Thats different....post some pictures when you are through with the tiling..:)
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
PostPosted: Tue May 29, 2007 6:45 pm
lol that's tight dude do your thing
PostPosted: Tue May 29, 2007 7:58 pm
I'm thinking of Speed liner ing (rhino/line x type stuff) In the floor board and bed of my new 4X4.
PostPosted: Sat Jun 09, 2007 2:31 am
What about that PVC pool liner stuff????
Bob.
