It is currently Mon May 25, 2026 10:49 pm
 Post subject: Power antenna
PostPosted: Wed May 02, 2007 1:53 am
Just was wondering if a power antenna will work ok on the LUV and what types could I get that will work?
http://www.purerockradio.net/
 Post subject: .
PostPosted: Wed May 02, 2007 6:33 am
Should, there's certainly plenty of room inside the fender/rust incubator.
FIAA: Color Guard
PostPosted: Wed May 02, 2007 9:01 am
you will have to do a slight mod to get it to fit... was going to put mine in the fender but couldn't get it to fit in the part behind the fender.... and i really wanted a sunken antenna anyway so i moved it behind the passenger door , more mods then the front needed ...., mine is a universal so others might fit just need to measure the holes behind the fender
PostPosted: Fri May 04, 2007 3:43 am
Thanks for the tips. I am not going to do a mod like that though! If I can find one that will work where the stock one goes then that is what I will do. There must be some shorter one out there that would work no problem. I don't care if it is long like the stock one, as long as it works fine.
