It is currently Mon May 25, 2026 2:40 am
 Post subject: 5 Lug Front Drums
PostPosted: Thu Jul 18, 2002 6:52 am
Ok, Maybe this is a NO Brainer. But what spindles and Rotors are you guys using to get the 5 bolt front wheels. I'm wanting to run Convo Pro's But No luck on the 6 hole. Can a set of S-10 front spindles and rotors work?
 Post subject: disc brakes
PostPosted: Thu Jul 18, 2002 7:25 am
On the opening page there is a information section. Inside there you will find a tech. article on how to convert your drums to discs and your 5 lug to 6. good luck,Bryan
PostPosted: Thu Jul 18, 2002 5:56 pm
Oooops, My Bad! I saw the swap from drum to disk and didn't even consider that article because I already have disk fronts... Thanks for the info. Called Moser Engineering today...
