It is currently Mon May 25, 2026 6:49 pm
PostPosted: Tue Mar 27, 2007 7:08 pm
I am in the process of building framework for a tilt front clip, however, I am doing it while the LUV is my only mode of transportation to and from work..... I am using 1.5" square tubing with a 1/8" wall thickness. As I am doing this after regular business hours, I dont have the shop to use, so I am using a cutting wheel on a 7 1/4" skillsaw, and will be having a buddy weld up the joints so I can keep working at home.... The only problem I am having is the radiator. Since I did not move the firewall back, I had to put the radiator between the bumper and frame, and since it is a large alum. I dont have the room to mount the hinge on the front bumper bolts, so we will see how I end up hinging it... Lets hope it turns out good. :?
76 Stepside, 350 TBI, 700r4, s-10 10bolt. Shaved handles, door locks, wiper cowl, tailgate, tail lights, gas filler hole. Lambo doors, 10.5" LED tail lights, carpeted dash and back of cab, bucket seats, soft bed cover (snap on type), tilt front clip.
PostPosted: Tue Mar 27, 2007 8:12 pm
well maybe this will help or not
http://www.chevyluv.zoomshare.com/1.sht ... ront%20end
PostPosted: Wed Mar 28, 2007 7:03 pm
I have checked that out and it has helped. I have decided to cut and the bumper brackets and weld them onto the uprights for the tilt hood so the bumper also turns down, I am gonna use the side mounting holes for my hinge point... Thanks for the site ctmandu.
