It is currently Mon May 25, 2026 5:55 pm
 Post subject: Door tightening
PostPosted: Sat Feb 24, 2007 3:29 pm
my doors are not snug when they are closed, how do you adjust them? they really rattle. 80 4x4.
PostPosted: Sat Feb 24, 2007 3:41 pm
LUVTruck.com's Cornholio
there are two screws on the door post. use a big philips screw jab and loosen them. move the whole mount back and snug it up. shut the door to make sure it closes right. adjust as needed, and tighten them up.
PostPosted: Sat Feb 24, 2007 3:43 pm
also it helps if you have weather stripping
PostPosted: Sat Feb 24, 2007 3:45 pm
Thanks pee_roy, I wasn't sure if it was in the striker or where.
 Post subject: .
PostPosted: Sat Feb 24, 2007 5:00 pm
Another good tip: I went to Autozone and got some rubber/foam strip adhezive back weather strip. I think it was about 3/4" wide, wider than what I wanted, so I split it down the middle and applied it to the surface where the existing door trim meets. No more rattle or wind noise.
Don't even notice it's there now.
FIAA: Color Guard
PostPosted: Sat Mar 03, 2007 2:25 pm
I got it done, it is nice now, no ratteling.
