It is currently Mon May 25, 2026 11:24 pm
 Post subject: GMC 16's on my Luv?
PostPosted: Thu Jan 25, 2007 5:20 pm
would anyone know if these are a good swap, I don't want to put in new studs or drill anything out, anyone have these on their truck with pics.
thanks
PostPosted: Thu Jan 25, 2007 6:19 pm
Swap Specialist Mod
well you wont have to get new studs of drill anything to run em. theyll bolt right up. just make sure you use the right lugnut that mates with the wheel, and make sure they lugnuts are 12x1.5mm. 1/2in lugnuts will strip out the first time you try to tighten them down.
now for pics, ive never seen a luv with those, but peeroys luv has GMC sierra 17s on it with a 205 40 tire. ill get a new pic of his truck later on tonite when he comes over.
PostPosted: Thu Jan 25, 2007 7:35 pm
Thanks for the help, now to photo shop my luv with the 16's
PostPosted: Thu Jan 25, 2007 8:32 pm
Dang.. I didn't know the lug pattern matched... :)
PostPosted: Thu Jan 25, 2007 10:39 pm
I know 8 hole lugs are the same. I could run ford, dodge and chevy on my 3/4 ton chevy 8 hole setup. I guess the 6 lug are the same too.
 Post subject: rims
PostPosted: Fri Jan 26, 2007 3:27 am
i have the GMC rims on my luv they are 16 with 205-40-16Image
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Jan 26, 2007 3:28 am
Cadillac Escalade wheels will also bolt onto the Luv pattern.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jan 26, 2007 3:29 am
Swap Specialist Mod
man, when your a minitrucker, you try and find any and all stock wheels that will fit your truck. hell im looking right now for a set of 17s from a 05 ford f250 for the pup. they have a 6 bolt pattern too!
PostPosted: Fri Jan 26, 2007 7:38 am
Be careful with the Ford rims as Ford put some real bastard bolt patterns on there trucks since 99 and i am not sure if the six hole wheel is the same as the GM.
 Post subject: Re: rims
PostPosted: Fri Jan 26, 2007 11:44 am
Bigger picture please. I can not see anything... I guess because I am old.. :roll:
PostPosted: Fri Jan 26, 2007 4:42 pm
luv 4x4 hub 3 1/4 across does that sound correct. they guy said his center is around 3in, on the GMC wheels. 1980 luv 4x4.
PostPosted: Fri Jan 26, 2007 10:25 pm
This is true on the 8 lug wheels for sure. I speak from used tire and wheel from Craigs list not fitting on my '86 Suburban experience.
Around 99-2001 I don't know exactly, Ford went to a metric hole spacing on the 8 lug wheels. They will not fit other 8 lug vehicles.
 Post subject: pics of GMC rims
PostPosted: Sat Jan 27, 2007 12:09 am
here you g oif it needs to be bigger lit me know no problumImage they are for sale if some one want them $350.00 o.b.o new tires on front
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Jan 27, 2007 12:19 am
On some of the GM wheels you need to hog out the center some.
 Post subject: rims
PostPosted: Sat Jan 27, 2007 2:15 am
on my rims i did't have to for the luv i did have to put a 1/4 spacer on it and they fit good
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Jan 27, 2007 9:52 am
:oops: Posted in the wrong thread. Disregard.
PostPosted: Sat Jan 27, 2007 9:54 am
A ha hidden info revealed :lol:
PostPosted: Sat Feb 03, 2007 10:15 pm
Hey, just an FYI- in near all cases, you can NOT run GM 8 lugs on older Ford 8 lugs, & it goes for both dually wheels & 3/4 ton wheels. The centers on the Chebby/Jimmy wheels is smaller than the Ford's. They no slide over the hub, in other words. :wink:
Mind you, thats in relation to stock wheels, not aftermarket ones.
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Sat Feb 03, 2007 10:21 pm
I only have used the wheels to go on a chev 3/4 ton.
PostPosted: Sat Feb 03, 2007 10:37 pm
I just wanted to point that out in case someone had thought about doing it the other way 'round, Papa.
stock Ford onto a Chevy- yes
stock Chevy onto a Ford- nope
