It is currently Mon May 25, 2026 5:09 pm
 Post subject: ignition wiring
PostPosted: Wed Jan 10, 2007 6:57 pm
i am making a new wiring harness for my 74 and i think i have the wires for the ignition right but i want to make sure.
radio, coil (+), solenoid power
solenoid(s), coil resistor
i think this is how it should be?
also here is how i did the light switch
power, power
park lights, dimmer, instrument panel lights
any help is much appreciated
PostPosted: Thu Jan 11, 2007 2:33 pm
The layout of your wiring is a bit confusing. If you could describe it a little better, maybe someone can tell if you're on the right track.
