It is currently Tue May 26, 2026 12:02 am
 Post subject: Roadgrater?
PostPosted: Thu Dec 28, 2006 11:46 am
I know quite a few of you guys are running s10 rear end which leads me to believe that the Luv and S10 are similair in width from frame rail to frame rail. This makes me wonder if a Air Ride Tech. roadgrater system would work on a Luv? Anybody gfot an oppinion on this?
I'm currently doing research before I buy my friends truck to find the best air bag setup for my budget(around $2000-$3000) and skills(no fab skills, lots of mechanical skill).
PostPosted: Fri Dec 29, 2006 12:42 pm
Front suspension are totaly different. Luv has a torson bar setup. S10 runs a conventional a-arm setup.
Front setup would need to fit a Isuzu Truck setup, torson bar.
Richard
PostPosted: Fri Dec 29, 2006 6:56 pm
Where in GA is BlackLuv 80??? He hasn't been here for awhile. He would be a good one to comment on that Giudo.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Dec 29, 2006 9:19 pm
You rang?...lol
I believe a s10 rear air ride set up would be close..But they do make universal ones that would prob be closer, far as the front it would probably be best to do away with the torsion bars and use a small tight clearance bag.
You may have luck finding information for either a isuzu pup/truck or trooper. Seeing the have similar and in most cases the same frame.
Users browsing this forum: Google [Bot] and 19 guests
