It is currently Mon May 25, 2026 2:29 pm
 Post subject: Wire Harness swap.
PostPosted: Fri Dec 29, 2006 1:03 pm
My 75 Luv's wireing harness is patched, cut, and just plan ratty. I don't have a extra couple of hundred for a new wireing setup right now.
I have a mid 80's chevy 1/2 ton parts truck and a 92' VW passat that I can strip the harness out of. I know the Chevy truck should be a little easier, just because it is a truck. The Luv is more of a Import so the passat harness may wotk just as well.
Chevy truck? Or Passat.
Richard
PostPosted: Fri Dec 29, 2006 6:51 pm
PapaG, I can't say anything about a Passat. I wouldn't know it the dimensions and/or the equipment was the same. Maybe you already know the engine is the same. Is it? Well here's a comment right out off the top of my head...why don't you just go get a bunch of primary wire and build your own harness. It can't be that hard. I was looking at my harness the other day and I had that thought. If I ever need it, I'm building my own. Why watch the grass grow when you could be building your own harness!!!
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Dec 29, 2006 9:19 pm
That is what I was thinking about saying. Or possibly buying a Painless wiring harness. I rewired my Luv race truck a couple years ago. I went to Menards, bought different rolls of wire and wired it myself. Good luck on which ever you decide.
PostPosted: Fri Dec 29, 2006 9:43 pm
I have a harness out of a 72 that is in perfect condition, let me know if you want it.
PostPosted: Fri Dec 29, 2006 9:58 pm
Say YES PaPaG!!! YESSSSSSSS!!!!!!
Image Image
PostPosted: Fri Dec 29, 2006 10:35 pm
It has the turn signal switch, all relays and the fuse box with cover, it does have some cut wires (only the one's going to the carb) other wise it is in perfect shape. I also have the harness from the main harness that follows the frame rail to the tail lights. Make me a offer, I was thinking 20 bucks plus shipping, but am willing to hear your offer. If you need a reference on me I can PM you a few names of members to that I have done business with before.
PostPosted: Fri Dec 29, 2006 11:41 pm
Sounds like a good deal to me.
PostPosted: Sat Dec 30, 2006 1:43 pm
Sounds like a terribly generous offer to me. If Papa G doesn't jump on this offer, he must just like pain. Is that a saddist or masochist? Can't remember.
Anyhow, TAKE THE OFFER!
lol,
Eric Q.
My build thread.
PostPosted: Sat Dec 30, 2006 3:54 pm
sa·dism (s!Ædiz Ãm, sadÆiz-), n.
1. Psychiatry. sexual gratification gained through causing pain or degradation to others. Cf. masochism.
2. any enjoyment in being cruel.
3. extreme cruelty.
[1885–90; < F sadisme; see SADE, -ISM]
—saÆdist, n., adj.
—sa·dis·tic (sà disÆtik, s!-, sa-), adj.
—sa·disÆti·cal·ly, adv.
mas·och·ism (masÆÃ kizÅÃm, mazÆ-), n.
1. Psychiatry. the condition in which sexual gratification depends on suffering, physical pain, and humiliation.
2. gratification gained from pain, deprivation, degradation, etc., inflicted or imposed on oneself, either as a result of one's own actions or the actions of others, esp. the tendency to seek this form of gratification.
3. the act of turning one's destructive tendencies inward or upon oneself.
4. the tendency to find pleasure in self-denial, submissiveness, etc.
[1890–95; named after L. von SACHER-MASOCH, who described it; see -ISM]
—masÆoch·ist, n.
—masÅoch·isÆtic, adj.
—masÅoch·isÆti·cal·ly, adv.
There you have it. It's masochism. #4
Image Image
PostPosted: Sat Dec 30, 2006 5:51 pm
WTF !!!!!!!!!!!!!!!!!
PostPosted: Sat Dec 30, 2006 6:48 pm
You all must be bored or something. This post got off track in a hurry AND in the wrong direction...
I need to take some asprin and lie down.
PostPosted: Sat Dec 30, 2006 6:54 pm
I have a harness with most of ther hookups but a couple of light connectors. Nothing labeled but still in the origianl black tape/ I would send you the whole mess for free if ya want it to use what you can. Getting rid of stuff.
PostPosted: Sat Dec 30, 2006 11:20 pm
Sounds like the way to try first. PM me and we will swap info and do it.
Richard
PostPosted: Sat Dec 30, 2006 11:21 pm
Sure too. I should be able to make a good one out of two.
Richard
PostPosted: Sat Dec 30, 2006 11:24 pm
Pain in moderation is not too bad... Sado- Maso what? :idea: :arrow:
Asprin sounds good too....Maybe a shot of Jack to chase it down :wink:
Richard
PostPosted: Tue Jan 02, 2007 11:24 pm
i dont know how much help ill be now seein as u have 2 harneses now, but if all goes to shit, i have one from a 76 luv that i have just stripped over in the land of OZ =)
 Post subject: Wiring Harness
PostPosted: Wed Jan 03, 2007 12:19 am
There is a guy on Ebay that builds wiring harnesses. I bought one for the LT1 going in my truck for $80.00.
