It is currently Tue May 26, 2026 12:15 am
PostPosted: Sun Jan 01, 2006 3:06 pm
got some pictures up for you guys check it out let me know what ya think
it's a 75 luv on 92 s10 blazer frame
Last edited by twist_of_fait on Tue Jan 17, 2006 8:28 pm, edited 2 times in total.
PostPosted: Sun Jan 01, 2006 3:28 pm
LUVTruck.com's Cornholio
wow that looks like your off to a good start. I wanna see it together now. :D
Good work, the finished product should look great.
 Post subject: the luv
PostPosted: Sun Jan 01, 2006 3:52 pm
in the picture that showes my whole truck the rear wheel is still not centered. my question is should i just leave alone or chop some more off the bed? i've already chopped 2" i think another 2-3" would be perfect. but its hard chopping the bed. i just want to know what you guys/girls think.
PostPosted: Sun Jan 01, 2006 5:14 pm
Swap Specialist Mod
thats pretty freakin sweet. it does need a section fo the bed in front of the wheel well cut out though. like sectioned forward.
 Post subject: Re: the luv
PostPosted: Sun Jan 01, 2006 10:47 pm
I didn't even notice that at first but I went back and looked, yeah I think it definately does need to be fixed. It's not super noticeable but once you notice it that's all you can see lol. The truck is freakin' sweet though man, I love everything you've done. Did you have to narrow the blazer frame to make it fit or is that something you did just for shits?
 Post subject: for some fatties
PostPosted: Mon Jan 02, 2006 12:59 pm
i did it so i can run a 295 50 15 cause im goning to be putting some flat tops and a cam and headers and a 305ci or 350ci throttle body on it.
PostPosted: Mon Jan 09, 2006 9:38 pm
fixed the tire offset and made the bed tilt back! i got pic posted of the bed in tilt($6.00 gate hinges and some flat bar)
PostPosted: Sun May 07, 2006 10:40 am
If you're bagging it, you could move the wheels forward and mount it with a 4 link if you'd rather not chop the bed. You'd have to have your driveshaft shortened, but it'll work fine.
PostPosted: Sun May 07, 2006 7:38 pm
that thing looks mean! 8)
PostPosted: Sun May 07, 2006 8:50 pm
that is a purty cool project, but i also think that you need to fix the rear wheel well issue, i noticed it right away and i think it kinda throws the truck off!
other than that, it is kick ass!!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Sat Jul 29, 2006 11:21 pm
2 door or 4 door blazer frame?
why not a pickup frame.
 Post subject: Wheel off center
PostPosted: Tue Aug 08, 2006 11:09 am
If you can do body work you can cut in the center at the top of the wheel well. Cut straight up 2 1/2 inches then straight across 2 1/2 inches beyond the farthest point forward and then straight down. Move the panel to where you need it, and fill in the top. Sounds complicated, but it's pretty straight forward. By the way, great project, and the truck looks really good.
PostPosted: Thu Aug 10, 2006 3:30 am
where is the pic of the tilt bed
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Aug 11, 2006 12:25 pm
Nice truck great stance Iam instrested in the roll pan is that custom sheet metal?
PostPosted: Mon Sep 04, 2006 9:46 pm
So did the frame go right under the luv body? or did you have to do any major mods. I understand that the body mounts probably had to be moved or modified.
PostPosted: Mon Sep 11, 2006 9:22 pm
What type of suspension you runnin right now? 2-link, 4-link? Cause you can't just chop up the bed to make the wheel look centered. Its uncenter due to the fact when you air out the bags, the rear axle is shiftin. When its aired out, the rear axle shouldn't move at all. If your runnin a 2-link, my personal opinion is to upgrade to a 4-link
