It is currently Mon May 25, 2026 4:53 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 328 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 17  Next
PostPosted: Wed Nov 01, 2006 1:30 am
LOL So I take it you like pie aswell...sorry lol
Yeah The Upper and Lower control arms where basically untouched
Lower arm was "smoothed" ( Currently Un-photographed )
Upper drilled for the 4 tiny bolts that hold the ball joint ( Also Not Done To The Driver Side In These Pics )
That Kinda Looks Bad On My Part
But the mysteries will all be solve with more pics. so the cats and the cradle and the silver spoon, little boy blue and the man on the moon as my wittiness I will try to solve all current speculation with pics.
PostPosted: Thu Nov 02, 2006 12:54 am
he thinks you cut it out
Im luvin it
PostPosted: Thu Nov 02, 2006 2:41 am
Cutting what out?
PostPosted: Thu Nov 02, 2006 2:46 am
I am in like sin for this swap !!! I just want to know how I can get machined pieces for the lower control arm. . . Someone do that and start selling kits and become a millionare !
-A
PostPosted: Thu Nov 02, 2006 2:51 am
Really and Truly I Could Prob Do That
I have just recently came a cross access to a water jet machine.....and there only one template both sides are the same just reversed
PostPosted: Thu Nov 02, 2006 3:07 am
Consider making the plates and the lower parts and a very detailed instruction manual and part list and sell it.
-Austin
PostPosted: Thu Nov 02, 2006 3:11 am
Who all would buy...i mean how many people want to use s10 drop spindles on a luv....lol i know i want to....need to buy some spindles
RedLuv80 Get Jason on some motor mounts or lemmie see yours
PostPosted: Thu Nov 02, 2006 3:13 am
Start a list, put LUV Rush at the top.
-A
PostPosted: Thu Nov 02, 2006 3:15 am
well i know for sure, that if you started marketing your little deal there, i bet aerospace would buy it from you for ALOT of money.
theres are alot of people that are lookin for a simple, cheap and easy way of converting to a common 5 lug pattern.
you could be making some bank in the near future man...
PostPosted: Thu Nov 02, 2006 3:29 am
Hmmmm...... That Is Good To Know....Need To Do It Redluv80 Needs A Set lol He Is Planing To Go The Monza Route I Think He Needs To Go This Way, So His Cragers Of His S15 Jimmy Will Fit Nicely On His Luv.
I Will See What I Can Do...Might Can Make The 1st 100 sets or more then sell out
Heck If Nothing Else The Thought Of Helping Another "LUV'er" Quoting Tj lol
PostPosted: Thu Nov 02, 2006 3:33 am
well if you were to produce some of the plates, i would definanly by a set.
PostPosted: Thu Nov 02, 2006 3:36 am
I'll Sell You The 1st Set Just Because You Where The 1st To Welcome Me To The Site And Commend Me On My Efforts.
PostPosted: Thu Nov 02, 2006 3:43 am
sweet action man!
i probably wont be the first to buy from you though. i dont have alot of extra money these days, but if you do make a couple sets, save some for me. i would apprieciate it!
one more question on the swap though.
what are you doin for the brake lines since your going american to metric?
PostPosted: Thu Nov 02, 2006 3:50 am
I Haven't Look Into That To The Fullest Extremes But I Believe The Stock Ones Will Work They Look Like The Same Size Hole Just The Head Of The Bolts Are Diff
If Not There Are Great Company's Out There Like Wilwood & Russel Who Offer Steel Bradded Lines Which Be The Way I'll Prob Go I'll Test That Out Tomorrow By Bleeding The Brakes And Seeing It They Will Hold. Prob Even Keep Them On For The Trail Run To Test It Aswell For Results.
I'll Have To Measure But It Looks Close In Other Words
PostPosted: Fri Nov 03, 2006 8:17 am
You can cut the brake line and use the nut from what ever way you want and reflare it IE; metric nut will fit american tube and vise versa this how my brake lines are made to fit the metric hoses. But soon i am going to use Russell braided lines as you have better braking than with rubber hoses.
PostPosted: Fri Nov 03, 2006 12:14 pm
make the kit id buy 1 .
PostPosted: Sat Nov 04, 2006 6:15 am
put me in line for just the lower ball joint plates.
PostPosted: Sun Nov 05, 2006 9:55 am
I also would take a pair of the lower ball joint plates.
Shawn, If you want I can host a website for you of this entire process. I have an unlimited amount of bandwidth on my server. Just let me know.
Just HTML code up a page with the pictures and I can throw it up for you.
Going through it I have the following list of parts needed:
1. 2 S10 spindles
2. 2 S10 upper and 2 lower ball joints
3. 2 S10 tie rod ends
4. 2 S10 rotors and disk brake calipers
5. 16 high grade bolts/nuts/washers (to mount ball joint plates to the A arms)
6. Heavier duty brake lines
Let me know if I missed something
PostPosted: Sun Nov 05, 2006 10:48 am
Shawn-newbie here- but have been following the thread on your conversion and it looks like it is definitely the way I'll be going, too.
Already found s-10 stuff yesterday, but didn't pull it til I could look at your pics closer. You really ought to knock out some sets of the plates, go ahead and put me in line for a pair. Skeeter
PostPosted: Sun Nov 05, 2006 9:46 pm
i'm in. how much for the whole kit? how fast can u come up with it? i'm ready to buy now!!! cash in hand or check in the mail whatever.
9.75 @138 496
luv to race
