It is currently Wed Jul 01, 2026 1:21 am
Post new topic Reply to topic  [ 330 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
PostPosted: Thu Mar 11, 2010 8:11 pm
DHPmike wrote:
I got information from speedwaymotors.com that the mustang II uses the same balljoint for the upper and lower.
I also checked this with a friend that had these spindles on a rod. The 727 may have the same shaft size but use a different length or perhaps a different body. Ill check the 727 tomorrow.
I have 2 orders for the Mustang II upper and lowers and Im using the K772 on both of those. If for some reason the 727 has to be used and its a large cup instead of the small one used by the 772 I can easily cut off the small cup and install the large one.
I am on the last set of uppers, and I will be done welding them together tomorrow. I may get them all cleaned up and balljoints pressed in so I can ship them.
For sure the parts shipping tomorrow are Steve W, Terry P and Hotrod Express.
tomorrow is the last day I will have the LUV jigs out unless someone wants to order some. when the jigs get put up it will be ablout 4 weeks before i can get back to them
any questions?
Cool, looking forward to them. I have 2 weeks to get ready for the big Florida race, this will be a big help. Thanks...
PostPosted: Thu Mar 11, 2010 10:17 pm
I have one set of S-10 balljoint upper arms to weld together and all the LUV stuff is done. I did not work on any arms today. too busy working on a truck to be used on a TV show.
I should have the last sets done tomorrow and also press in balljoints and ship parts tomorrow.
Michael White
www.dallashotrodparts.com
PostPosted: Fri Mar 12, 2010 2:23 am
Ok i have some Qs...
i have a 72 luv it has the stock suspension on the front and i want to turn it into a 5 lug
if i get your tube arms uppers and lowers i can put chevy s10 spindles?
thanks
SALINASRACING.COM
PostPosted: Sat Mar 13, 2010 3:58 pm
yeah if you get the uppers and lowers you can run s10 spindles thus converting it to a 5 lug
Epic Fabrication.
KAOS
PostPosted: Sat Mar 13, 2010 6:31 pm
oh ok cool thanks
so how much is this set up?
SALINASRACING.COM
PostPosted: Sun Mar 14, 2010 6:26 pm
with shippin and all when i got mine i paid 525
Epic Fabrication.
KAOS
PostPosted: Sun Mar 14, 2010 9:25 pm
umm not bad..
i need to tell DHPmike i want to place my order
SALINASRACING.COM
PostPosted: Wed Mar 24, 2010 12:20 pm
I'm not sure if you've already completed this or not, but if you need, I've got some lower control arms I could send you to work off of. Just tore em off and their just layin around...
PostPosted: Mon Apr 19, 2010 4:36 am
I have all the jigs made for this for both s10 spindles and for mustang II spindles.
Ive had to tweak the lengths of each to work with the luv frame but we are all good now.
Michael White
PostPosted: Tue May 18, 2010 1:18 am
just curious if anyone who has installed the DHP arms has a parts list of whats needed.
ive got s10 spindles, calipers, rotors/hubs and ill be placing my order for the arms. w/bag plates
i went back in this thread to look because i remember at one time someone said almost all the luv tie rods and steering parts work but an ... outer? tie rod needs to be replaced with a nissan part? im gonna re-read this again and see if i cant find it.
but maybe someone could put a parts list together for bag and non bag owners and make it sticky somewhere on the forum?
mike are you busy with other stuff? i dont have a time crunch or anything, but id like to place my order ASAP
PostPosted: Tue May 18, 2010 1:25 am
p.s. anyone who has DHP arms installed post pictures!
PostPosted: Tue May 18, 2010 4:38 am
I am finishing up my install, will do a pictoral when completed...
PostPosted: Wed May 19, 2010 1:25 am
+1
SALINASRACING.COM
PostPosted: Sat May 22, 2010 5:59 am
im always busy.
the good thing is I have hired a friend to come on saturdays and turn bushings and sleeves on the lathe. This will cut down my time to build a set by one third. he will keep going until Im way ahead on bushings then i will have him making other parts. This is a guy that worked for me before so he knows the parts I make.
let me know if you have questions. 77, try to call me again today. I may or may not hear the phone but I can call you back asap
Michael White
PostPosted: Fri Jan 13, 2012 7:07 pm
anyone have pics of these arms with air bags? i would like to see them if possible. I take it with this setup there is no need to Z the frame to lay it out.
Kelbone
I want to be a minitrucker when I grow up
PostPosted: Sat Jan 14, 2012 7:27 am
I have ordered and paid for my arms over 12 months ago now. Mike was good and updated me whenever I asked but for the last month or do I have tried to reach him daily with no luck and he won't return emails calls or texts. If anybody knows another way to get in contact would be greatly appreciated
PostPosted: Sat Jan 14, 2012 9:28 am
go to the web site and hit the contact button. thats not right waiting a year for something thats paid for.
Kelbone
PostPosted: Sat Jan 14, 2012 8:51 pm
Tried that no luck
PostPosted: Sat Jan 14, 2012 9:59 pm
makes me think the Toyota front clip swap may be easier after all and faster huh.
Kelbone
PostPosted: Sun Jan 15, 2012 12:36 am
I have not seen him on another forum we are both on since before Christmas...
