It is currently Mon May 25, 2026 12:18 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 328 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
PostPosted: Sun Sep 02, 2007 11:03 pm
Good for you. Knock yourself out- literally.
PostPosted: Sun Sep 09, 2007 1:48 pm
Ah, and I hope you have a lovely day as well. :smt023
PostPosted: Mon Feb 04, 2008 2:54 pm
So.... Are these going into production?
PostPosted: Wed Feb 13, 2008 7:32 am
i too am doing this conversion the plates were easy to make my problem was the s10 rotor was out further than the stock so i made new plates and moved the holes further out and had to mod the upper control arms ill post pics soon if u would like?? :alcholic :shocked!:
PostPosted: Wed Feb 13, 2008 10:54 am
heck ya post some pics! I did just converted over to 5lug with a early Toyo knuckle setup, Ball joint to ball joint, but with the Cragies they are out about 1/2" too far and I'd like to find a way to bring them in a bit with a control arm mod. I wonder if anyone has found an SPC upper control arm that would fit on a LUV, that would solve a LOT of lowering issues.
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
PostPosted: Sun Feb 24, 2008 8:22 pm
Been a while.... Between daily stress of the shop and constant computer malfunctions I haven't been on here in a while.
But to answer your question, Yes these can be put into production. I have actually spent several of the last couple of months putting the product to additional testing for R&D. I have modified the design for easier installation. Then of course I currently have two designs as well. One using a press in S10 lower ball joint, The other using a explorer lower ball joint with a lock ring. Using the S10 lower ball joint is cheaper yet a lock ring gives people that added piece of mind. Neither design has brought up any issues with safety or fatigue.
As far as appearance, most GM wheel fits with inside the fenders.
All serous inquiry PM me and I will see what can be arranged.
PostPosted: Wed Feb 27, 2008 4:22 pm
i done the s10 ball and it works good
Im luvin it
PostPosted: Thu Apr 03, 2008 8:19 pm
I'm tired of waiting on plates. Gonna try and make my own or go to the Aerospace conversion or forget it altogether.
PostPosted: Fri Apr 04, 2008 6:08 am
I went with the Aerospace kit. It was kinda pricey, but when you are running high 9's at 130-something mph, I wanted to be safe. The kit is also very easy to install. Just my 2 cents worth.
PostPosted: Fri Apr 04, 2008 7:47 am
Thanks, just tired of waiting and want to get on with the program. Mine won't be near that for a long time. I just want to get stuff done and then go from there.
PostPosted: Thu May 21, 2009 11:22 pm
It has been a while since anyone has add to this. Who has actually done this conversion and had their running and driving car on the road since doing it? Any issues?
PostPosted: Fri May 22, 2009 6:08 pm
Hello all. First This is my first day in this forum. I am on several others and banned from a couple more....
anyway, Im here because I was sent the link by a guy thats trying to do a conversion. I sent him an email after seeing his post on SSM about anyone making tube arms for the LUV that would use a different spindle. If I remember correctly he wanted to run a Toyota spindle.
Well, Im about to go to the local pick n pull tomorrow as I do most weekends to do some "wrecking yard research" as I call it. I usually buy at least one control arm or spindle and sometimes both. I will be looking into the types of arms these things have and Ill see what I can do to make these.
I currently make Toyota arms that use S-10 balljoints. Why? because the taper and hole sizes are the same and the S-10 balljoints in aftermarket form have much more travel. The upper especially.
I can make a set of tube arms that fit the LUV chassis and use pretty much whatever spindle you want. Id prefer a Toyota or S-10 spindle. All I need to get the ball rolling is ONE stock upper and ONE stock lower.
I dont have to cut them up or anything I just use them for measurement and dimensions purposes. So Ill be looking for these pieces tomorrow. If I cant fond any I will have to see if he or someone else will send one. I would need the set over a weekend. Thats about all the time I need to get the jig made.
The real question for me? Is there a market for these? Id have to be able to sell about 3 sets to break even on making a jig and all the research needed.
thanks and if theres some advertising rules that Im close to breaking please let me know. thanks!
Michael White
www.dallashotrodparts.com
PostPosted: Fri May 22, 2009 6:28 pm
i believe that you must get permission from the administrator of the site wouldnt hurt to ask for sure tho
viewtopic.php?f=8&t=10542
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Fri May 22, 2009 7:11 pm
That might be kinda cool to have made if possible. Of course with a cutting torch, welder and some knowhow anything is possible right. 8O :roll: Just kiddding. :ebiggrin
PostPosted: Sat May 23, 2009 10:29 am
OK well Im going to do the research today and Im probably going to be making at least this one set. I will have to set up at least a temporary jig.
I will post pics of my progress in case any of you want to know what you can do to mod stock arms or build your own.
I will also look into advertising to see what I need to do to be able to talk about these here as a seller. thanks for your input
Michael White
PostPosted: Sat May 23, 2009 1:02 pm
If it is permissible, then I would suggest starting your own thread, as most people on this board avoid this thread like a plague. And please post progress pics, I would like to see the finished product and wouldn't mind having a set for later...
PostPosted: Sat May 23, 2009 10:28 pm
what happened to this thread that makes" people avoid it like the plague?"It seems like a good idea.I would be interested as well.
76 mikado project,mean green
PostPosted: Sat May 23, 2009 10:37 pm
I did start a thread. I guess I will see if its ok. I didnt see any way to contact the site.
Michael White
PostPosted: Sun May 24, 2009 5:26 am
just pm ben or any moderator and they can help you out
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sun May 24, 2009 5:32 am
Don't worry about the thread, It is long been water under the bridge as far as I am concerned and no big deal anymore. Heck just start a new one and go from there, I would think it would be ok in my opinion, I think evn if it is related to the other conversions or what have you, it is a great idea and would be beneficial to all of us. I still have my s-10 spindes waiting to be used for anyones conversion.
