It is currently Mon May 25, 2026 7:40 am
PostPosted: Thu Apr 10, 2003 12:50 pm
Do to recent posts about engine bay heat on v8 luvs, I thought I could add the fender vents and shaker hood scoop from my 79 T/A to my luv for the heat to escape from. Mine hasnt run yet but it sounds like a common problem. Not to sure about the look though. What do you all think.
PostPosted: Thu Apr 10, 2003 9:29 pm
before you start adding the vents see how hot it runs first. how hot it will run has many factors ,how much power,how big a radidator ,what fan ,i run a 19"x21"alumn rad with a fan shourad and a fan clutch and fan from a 280z i can go through drive through at mc d's no problem the highest temp i see has been 210
PostPosted: Fri Apr 11, 2003 8:16 am
I mocked it up last night and it just looks like ass. Scrap that idea. My original thought was to have my freind fab a cowl for me and weld it on. Itll look better anyways.
PostPosted: Fri Apr 11, 2003 1:24 pm
It looked like ass... Too bad. It sounded like a cool idea.
PostPosted: Wed Apr 16, 2003 6:23 am
I had no problems with heat on my truck. But as you can tell there is no inner fenders at all and I have a large radiator ( full size pickup) and 2 14" electric fans. No engine driven fan ( couldn't spare the power to drive a fan).
stripped and just a memory!
PostPosted: Wed Apr 16, 2003 7:49 am
My truck runs at 190 and is cooled by a small 4 core Rad,12" plastic fan on motor and a 14" eletric fan but the truck also has a cowl hood, the thing is to make sure you burp the cooling system of air you don't want air trapped in the motor.
PostPosted: Wed Apr 16, 2003 11:07 am
And make sure you use a coolant recovery tank with the correct type of cap on the radiator. If the motor burps air, the tank provides a source of coolant to keep the system filled
Users browsing this forum: Google [Bot] and 14 guests
