It is currently Mon May 25, 2026 10:54 pm
 Post subject: newer 6 lug rims
PostPosted: Thu Aug 24, 2006 4:59 pm
Will newer 6 lugs rims work on my 81?
Example
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Thu Aug 24, 2006 5:49 pm
Banishment Pending
Not unless you drill out the center hole bigger. starting in '88 Chevy 6 lug rims were hubcentric instead of lug-centric like Isuzu,Toyota,Nissan, and Mitsu 6 lugs
PostPosted: Thu Aug 24, 2006 9:41 pm
I think That's what Pee Roy has on his truck. Ask him what he did.
http://forums.luvtruck.com/profile.php? ... ile&u=1235
PostPosted: Fri Aug 25, 2006 7:26 am
Bolt pattern will be the same, but backspacing is different. I put a set of 15x7 Rodeo rims on my '83 P'up (same as your '81 LUV). They don't tuck in front quite as well, but they're fine on the rear (I'd never noticed that the rears sit deeper in the fenders). Here's a photo of an '82 LUV 4wd with the same wheels I have...
As mentioned above, with 4wd, the center hole may need to be bored out on some rims.
PostPosted: Fri Aug 25, 2006 10:48 am
Banishment Pending
rondog, PeeRoy's truck is a 2wd, therefor eliminating the too-small-hole problem as 2wd don't have the front hubs to contend with
PostPosted: Fri Aug 25, 2006 12:01 pm
Swap Specialist Mod
http://forums.luvtruck.com/viewtopic.php?t=10868
PostPosted: Fri Aug 25, 2006 9:31 pm
Ahh. I over looked the 4X part. I'm from the big city. I've never owned a 4X. :lol:
Users browsing this forum: Google [Bot] and 24 guests
