It is currently Mon May 25, 2026 4:33 pm
 Post subject: alternator placement
PostPosted: Sat Jul 30, 2005 4:28 pm
I recently put an electric water pump on my truck. Caused a new problem, where to put the alternator. Where do some of you V8 guys have yours mounted. I have found only 1 good spot. The headers are in the way almost everywhere. I have to make sure I can get a belt small enough tho. It's only going to be about 14 or 15 inches long. Anyone with a V8 considering an electric water pump, if your alternator is on the pass. side, don't get a Moroso, it's just going to make new problems for ya.
PostPosted: Thu Aug 04, 2005 1:36 pm
Japanese Redneck
I am currently using a modified low mount bracket. the only problem is there is no adjustment on it so I had to bump the belt on and its very tight... probably too tight.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Aug 08, 2005 11:15 pm
Image Well I cant see why runnin an electric w/p would make you have to move the alt. but you can get all these brackets at any parts store.Not a great pic, but I think you get the point.
