It is currently Mon May 25, 2026 7:32 am
 Post subject: rotor up grade
PostPosted: Fri Feb 20, 2004 12:43 pm
does any one know of a five lug rotor that is a dierct bolt on... or a rotor that needs very little modification to fit
PostPosted: Fri Feb 20, 2004 1:17 pm
you have a PM
03Cobra
PostPosted: Tue Feb 24, 2004 12:00 pm
post up i need to get rid of my drums up front and need to know what will work
 Post subject: rotors
PostPosted: Tue Feb 24, 2004 1:11 pm
What year luv do you have, and is it 4 wheel drive?
PostPosted: Sat Feb 28, 2004 3:13 am
i want 5 lug too, not like the chevy 5 lug, like ford half ton five lug. 5 on 5 1/2
PostPosted: Tue Mar 16, 2004 2:47 pm
75 2wd.
can someone post up a close up photo of factory luv rotors drilled for 5 lug.
do you drill the rotor or just the part that bolts to the rotor holding the studs?
please post pics
i got complete spindels for 25 bucks for both. complete with rotors and all disk brake stuff still intact. want to see what they look like up close on the rotor.
i currently have drums drilled for 5 lug 4 1/2 pattern. i didn't do it so i will be on the hunt for someone else to do the new rotors
dallas has to have someone that can do it. mosier no longer does luv rotor drilling i called them today
PostPosted: Tue Mar 23, 2004 2:00 pm
any body??
PostPosted: Tue Mar 23, 2004 2:08 pm
my old rotors used to have a 5/8" aluminum adapter plate bolted to the hub to get the desired bolt pattern.
sorry, but I don't have pics of them.
03Cobra
PostPosted: Tue Mar 23, 2004 3:14 pm
yeah the only thing for changing bolt patern is adapters...unless you get them re-drilled....and its kinda spendy....i found a machine shop that might do it he said gring in my rotor and he'll see what he can do!
