It is currently Mon May 25, 2026 8:16 am
 Post subject: here goes nothing
PostPosted: Mon Mar 15, 2004 3:36 am
As of March 14 at 7:53pm mt time I have decided to do a lil trick that we tried once on a old Toyota. Since I am begging for leg room and engine room in my LUV, I am going to make what you would call a pro-street LUV. I am going to take my long bed frame, move the body back and extend the nose 4". I will then be buying a frame rail kit and narrowing the rear half of the frame (under the bed) to about 2ft wide to allow extemely narrow rear end and coil over suspension. This will allow me to keep my 350 without having to chop the firewall. Im going to be going around to some of my local customizing shops and seeing if anyone will be willing to sponsor me, as I already am scheduled for some races this summer. What a way to advertise. Chevy luv that will race and beat your Corvette :twisted:
PostPosted: Mon Mar 15, 2004 5:34 am
Good luck wicked :!:
PostPosted: Mon Mar 15, 2004 6:48 pm
if you are putting in a 350, you don't have to chop the firewall.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Tue Mar 16, 2004 1:15 am
I already got the 350 in my LUV. No you dont have to chop it, unless you dont want to put a body lift on it to clear the tranny in the hump (350 turbo). But you must remember, I built mine by myself and with minimal tools. I used an old Yamaha forklift to manuver the motor into place, and the only thing that got my truck off the ground was a pair of small ramps. The water pump is about 1/2" away from the radiator, and the valve covers are 1/32" away from where the firewall use to be, the HEI dist is 1/2 inside the former firewall, 1/2 outside. But in all actuallity if you chop the original motor mounts off of the frame and weld new mount plates directly to the frame (unless your like me and have the truck on the ground, in which case the pan would drag) it would fit.
PostPosted: Fri Mar 19, 2004 9:09 am
LSX LUV Owner
we moved my motor farther forward so we wouldnt have to cut the firewall for the hei distrubutor.
