It is currently Mon May 25, 2026 4:25 am
 Post subject: Bias ply or radial
PostPosted: Tue Mar 09, 2004 7:44 pm
I am in the process of putting swampers on my truck but i was woundering if i should get bias ply or radials. i heard for one of my buddies that bias plys wore out his front end parts. which is better?
PostPosted: Tue Mar 09, 2004 7:52 pm
radials will drive much better and will last longer, if you are going to be street driving your truck, go with radials.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Tue Mar 09, 2004 8:44 pm
radial swampers aren't all they're cracked up to be. more expensive than the bias, and i've heard really bad things about them blowing sidewalls on the street. they don't last much longer than their bias cousins and are heavier too
i'd get bias...if you're gonna get a swamper, you might as well go all the way
PostPosted: Tue Mar 09, 2004 10:01 pm
radials put a bigger foot print on the ground than bias do
PostPosted: Tue Mar 09, 2004 11:34 pm
their is pro and cons to both of them i personally take radials i dont have much time to off road but i wouldnt mind havin a set of bias mounted on some other wheels then make local tire shop zip on the bias when goin muddin and then take them back and ask them to balance your wheels after muddin and they ll clean them up ha ha ha
Users browsing this forum: Google [Bot] and 17 guests
