It is currently Mon May 25, 2026 7:40 am
 Post subject: Lift shackles
PostPosted: Tue Feb 24, 2004 9:29 pm
Does anybody know if a toyota lift shackle will work on the luv?
PostPosted: Tue Feb 24, 2004 10:34 pm
dude, if they dont, just make your own. they really arnt hard, but they should work.
 Post subject: lift
PostPosted: Wed Feb 25, 2004 1:59 pm
What I'm thinking about doing is swapping in the 'yoda axles and trying a toyota suspension lift. The shackles are temporary.
PostPosted: Wed Feb 25, 2004 11:30 pm
the toy axles would be a good idea. cheap, lots of aftermarket and pretty durable. plus the front drop is on the passenger side so it should work with a stock t-case. probably have to do some driveline mods too
PostPosted: Thu Feb 26, 2004 12:49 am
Measure the spring width and the diameter of the bolts on the stock shackles and compare. If they match or close enough then they'll work.
Edit: assuming you have the toy's to measure I guess. Didn't think that one through before I started an answer. :P If you are looking online at some part call or email them and ask for some dimensions or give them yours and what you want. http://www.independent4x.com would be a good place to look for more Isuzu specific parts. Email them and I bet the owner can find something that he carries that will work.
Users browsing this forum: Google [Bot] and 14 guests
