It is currently Mon May 25, 2026 2:43 am
 Post subject: HELP PLEASE
PostPosted: Thu Jun 30, 2016 12:42 pm
We are currently building a 1980 Chevy Luv, and the customer wants to do i small lift to run 32s, or 33s. We are thinking Spring over in the rear, but we are stuck on what to do with the front, because it seems as nobody makes lift kits for these trucks. Any advice would be greatly appreciated.
Thanks,
Jonathan
 Post subject: Re: HELP PLEASE
PostPosted: Thu Jun 30, 2016 1:57 pm
Jonathan,
I read your post, not knowing that it's a topic I'm completely ignorant on. So, I'll offer the only advice I have: use a Subject that summarizes your question or issue. That way, it's more likely to get the attention of someone who can answer it.
On the other hand, if everybody who had a question used "HELP PLEASE" or one of its many minor variations, things would get pretty confusing and Subject lines would be pretty useless.
Wish I could help with your question, sorry. :(
PostPosted: Thu Jun 30, 2016 3:17 pm
Many Trooper parts are alleged to swap to the LUV without too much pain, although I am not sure how much you really gain in terms of height. See below for a link to a similar question and answer (found using the query "lift kit" in the site's search function). You will probably find your best info via site search. Unfortunately, this is a reasonably common question that, to be a little blunt, most users will be too bored of to contribute much effort..
viewtopic.php?f=24&t=29355&p=213659&hilit=lift+kit#p213659
Subject search for 'suspension lift'
search.php?keywords=suspension+lift&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Subject search for 'lift kit'
search.php?keywords=lift+kit&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Else, it sounds like you may have some reasonably heavy frame mods in your future.
Please do share your learning with the community! If you come up with a new solution, we'd love to see photos, etc.
PostPosted: Thu Jun 30, 2016 5:07 pm
Thanks,
Jonathan
Assuming you are talking about a stock '80 LUV 4x4? You lift the front by tightening the torsion bar adjusters, one full turn equals about 1/4" of lift. You can get maybe 3", but don't go so far that you lose all downtravel, ride will be very harsh & bouncy. Lift the rear with helper springs (stiffens the rear to match the lifted front) & longer shackles as needed to level the truck. SOA in the rear will give about 6", you just can't lift the t-bar front that much. With near max crank on the T-bars and the rear height matched about the max tire size is 31's, even those may require front fender trimming or application of a BFH, depending on the width & backspace of the wheels. Any bigger tires will need a body lift and/or serious front fender trimming/hammering. A body lift introduces it's own set of problems (or at least differences), but it will decrease the amount of trimming required. The rear fenders should be fine, it's the fronts that are the problem.
Others have done what you want, maybe they can chime in, maybe even provide pics. If you can go back at this stage & edit the subject title to something like "LIFT HELP PLEASE" you are likely to get more responses.
On a side note the larger tires will make an underpowered truck even more so. You can correct the speedo somewhat with a driven gear with fewer teeth.
PostPosted: Wed Jul 06, 2016 10:25 pm
Thanks,
Jonathan
Regarding the front, you could get the A-arms off a Trooper and flip top Ball joint.
Here's the link on that thread: viewtopic.php?f=7&t=16042
