It is currently Mon May 25, 2026 2:43 am
 Post subject: 4 to 2 headlight swap
PostPosted: Sat Mar 12, 2016 4:47 pm
I have a damaged headlight bezel on my 72 luv. I can't seem to find much of anything for parts. There are a few of the later model trucks with 2 front headlights in a local wrecking yard. Is it possible to convert the 4 head light front end to a two head light front end? And if it is possible to do is it pretty much a straight unbolt the old and bolt on the new?
PostPosted: Sat Mar 12, 2016 6:48 pm
Some minor mods but it's doable. If it is just a bezel issue you could probably find one in the classifieds here...
PostPosted: Sat Mar 12, 2016 7:29 pm
I have some parts left from my LUV sent you a pm
PostPosted: Sat Mar 12, 2016 11:17 pm
Thanks mytmouz I figured from what little I really know about these trucks they seem pretty similar through out the years. It also seem like parts in general are hard to come by at least locally and even harder to find for the earlier trucks.
Dseed I PM sent to you.
