It is currently Thu Jun 18, 2026 8:53 am
 Post subject: spray paint
PostPosted: Fri Nov 14, 2014 11:09 am
Hi
What spray paint do you use? rustoleum? krylon?
thanks
 Post subject: Re: spray paint
PostPosted: Fri Nov 14, 2014 12:53 pm
None
PostPosted: Fri Nov 14, 2014 2:47 pm
for what?
PostPosted: Fri Nov 14, 2014 8:19 pm
luvv wrote:
Hi
thanks
for painting the truck with a rattle can? none
for other stuff I usually end up using rustoleum
PostPosted: Fri Nov 14, 2014 9:58 pm
Spray paint does not have hardner in it. It does not hold up well to chemicals and fades quickly. That is why I said none. It's pretty easy to mix and spray from a gun.
PostPosted: Tue Nov 25, 2014 9:42 am
There are a some of posts here on doing this. One member did his 4x4 luv. Looked good. Google $40 - or $50 paint job, a Rustoleum Paint Job. Some are rolled on. The original one is like 40 pages on some forum... Long read. I can not argue for it or against it..I did a flat black rattle job on my 56 Ford in the later '60s, hot rod style. It has been done. Some several years old. A Chevy Corvair comes to mind. The long one was on a Mopar forum of some type.
