It is currently Mon May 25, 2026 3:32 am
PostPosted: Wed Dec 05, 2012 2:11 pm
If you are running skinny tires up front on your driver, did you install a brake proportioning valve to take load off of the front tires? If so what did you use? My rears are 25x10in.
PostPosted: Wed Dec 05, 2012 8:23 pm
I run a 165 r 15 front tire on mine . I have aerospace brakes in all 4 corners with Mopar mastercylinder . No problems .
I have run the same tire with ford truck drums in the rear wiith facotry proportining valve and had no problems . The smallest rear tire i have run is 26" . The smallest front 22.5 "
