It is currently Mon May 25, 2026 3:32 am
 Post subject: 4 link adjustments
PostPosted: Sun Nov 27, 2011 4:46 pm
I just bought a Luv with a complete custom tube chassis. I need advise on how to setup the 4 link. location of instant center, position of links, etc. It has a 355 with about 550 hp, glide, 5500 stall, T-brake, 31/13.0x15 slicks.
 Post subject: Re: 4 link adjustments
PostPosted: Sun Nov 27, 2011 6:19 pm
DO you have a racingjunk forum login? If so I can give you a link, if not, I have the whole file somewhere on my 'puter...
PostPosted: Sun Nov 27, 2011 6:37 pm
yes I do have a racingjunk login. I set my IC at about 46 inches and about 7.5 inches up from ground. the bottom link is running slightly nose down. the spread between the upper and lower link is 11 inches at the rearend and about 5 inches at the front. bottom link is about 25.5 inches long. Maybe I am at a good starting point.
PostPosted: Sun Nov 27, 2011 7:10 pm
PM sent...
