It is currently Mon May 25, 2026 8:20 am
 Post subject: Lowering my LUV
PostPosted: Sun Oct 24, 2010 10:08 pm
Well I'm working on a project using my LUV's frame. How far can you lower it before having to bag it or do any major work. Such as how far can you lower it by cranking down the t-bars I just need to know mostly on the front end the rear is easy.
 Post subject: Re: Lowering my LUV
PostPosted: Mon Oct 25, 2010 6:30 am
u can crank the t bars all the way down jus gona make the ride kinda rough....and the lower arm will be sittin on the bump stop thats as low as u can go with out baggin it..jus make sure u dont unscrew the t bar completely out seen a nissan take it out and rode like shit and went clank clang all the time
Epic Fabrication.
KAOS
PostPosted: Tue Oct 26, 2010 10:12 pm
I cut my front bumpstops about in half and re-indexed the torsion bars,dropped the back about 2 5/8,doesnt ride too bad,go to project/builds thread towards the end of my build if ya want.The back could prob go an inch and a half lower the front not much without being to harsh to drive.
76 mikado project,mean green
