It is currently Mon May 25, 2026 3:18 pm
 Post subject: Leaf Springs
PostPosted: Sun Mar 14, 2010 8:43 pm
So, anybody know besides getting add-a-leafs if there are compatible leaf springs from other vehicles like an S-10 or something that will work on a 78 LUV? I wanna raise the back up a little bit but I don't want to have to get a bunch of add on stuff.
For a wounded man shall say to his assailant, If I Live, I will kill you. If I Die, You are forgiven. Such is the Rule of Honor.
 Post subject: Re: Leaf Springs
PostPosted: Wed Mar 17, 2010 8:10 pm
Couldn't you just get/fabricate some longer spring shackles? Way back in the old days of jacking up cars (the rear end only), that was a method often used. Of corse if they get too long the rear end will wander side to side a bit. But I don't think you want it up THAT high.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Mar 20, 2010 11:23 am
Getting your springs re arched by a spring shop is good. Adding blocks are the cheapest way.
PostPosted: Sat Mar 20, 2010 1:39 pm
Blocks are going to lower the back.........
PostPosted: Sat Mar 20, 2010 8:45 pm
I thought he was in from down under. It works the other way down there, doesn't it?
Brain fart.
PostPosted: Mon Mar 29, 2010 1:22 am
Sounds like papag is hitting the Colorado Cool Aid again!!
PostPosted: Mon Mar 29, 2010 1:29 am
Sorry PapaG, couldn't resist! Actually a set of air shocks work out very well, I can raise the rear of my 78 stepside a good 6" by inflating my air shocks and these are pretty cheap on e-bay. Mine have lasted over 10 years and still don't leak, pretty good for under $100.!
If you really want to raise it higher you can relocate the springs from under the axle to on top of it, just needs new spring saddles, BUT you will have to calculate the correct drivelshaft angle to avoid driveline vibrations and u-joint wear.
PostPosted: Mon Mar 29, 2010 4:14 pm
:) :o 8O Who me... Texas cool-aid :wink:
PostPosted: Mon Mar 29, 2010 7:44 pm
Yeah I know about that Texas Soda Pop, I also remember there are only two types of people in the world-those that are from Texas and those who want to be!!
