It is currently Mon May 25, 2026 7:38 am
 Post subject: axle under leaf springs
PostPosted: Mon Nov 30, 2009 9:12 am
ok, i need to know before i go into the process of putting my axle under the leaf springs if there is anything thing that i would have to buy( i have tools so please no smart comments).
thank you
80 Chevy LUV 4x4
PostPosted: Mon Nov 30, 2009 11:32 pm
Your axle tube is 3" in diameter, the spring pack is at least 1" thick, so you are raising the rear a minimum of 4". It will be very difficult to get the front end level, about 3" is the max for a torsion bar crank. If you have a a driveshaft carrier bearing the rear portion angle will be so steep that you will get shudder on take off. When you relocate the spring clamping plate to the top of the spring pack you have to lower the bottom shock attachment point or the shocks will bottom out before the axle snubber makes contact- the shock attachment point is 4" higher but the snubber contact point is only the spring pack thickness higher.
PostPosted: Tue Dec 01, 2009 8:37 am
what if i removed a leaf spring or two? or just if i do lift the back just raise the torsion bars and use my "lift blocks as lowering ones and lower the rearend 1"?
80 Chevy LUV 4x4
PostPosted: Tue Dec 01, 2009 9:19 am
I used Trooper sprins and rebuilt mine to get a 3"-3 1/2" lift
PostPosted: Mon Feb 15, 2010 6:01 pm
are all stock luv axle tube's 3"? i was searching for this information
PostPosted: Thu Mar 04, 2010 1:15 am
The axle tube is 2.75"
1975 V8 Luv
1980 Bagged Luv
Users browsing this forum: Google [Bot] and 22 guests
